- Sun Apr 13, 2014 9:49 pm
#34722
Norm just picked up on what you said about the C5 forks, NO loctite is required.
They are designed like a camel, functional but wtf was the guy thinking..
I thought they were having a laugh when i read that the fork has to be removed from the bike in order to change/top up the oil??
So lets see, jack up the bike, remove the brake calliper, mudguard, speedo drive cable and wheel.
Also the clutch cable from the nacelle, because the outer WILL get chewed by the allen key
You couldn’t make it up really.. Because you can drain the fork from the allen bolt in the slider but there’s no fill hole in the top..
Under the chrome screw is the fork cap, a piston like lump with a left hand thread and o ring turned by the usual 12mm key..
This screws internally into the fork tube, anti clockwise to tighten looking downward..
The fork tube has the usual external RH thread into the nacelle.. Sooo if you turn anti on the plug it will tighten into the fork tube and the fork tube will tighten into the nacelle, Clear? with me so far? he he…
How do you get it out..? If you release the pinch bolt on the lower tree and turn the plug clockwise you will wind the tube out of the nacelle.
Great except your left with a tube with a bloody tight plug in the end and no way too grip the tube…
Plan B, loosen pinch bolt and turn clockwise on the key until you feel the tube give in the nacelle. Now tighten the pinch bolt and go clockwise to break the plug in the tube.. Release the pinch bolt and using latex gloves for grip unscrew the fork leg from the nacelle complete with fork cap…
Remove cap and invert over a bucket to clear oil. NB Two springs in this model,Long spring as in all and a short rebound spring… Enough, i’m off to bed… gwilly
