- Mon Aug 20, 2012 9:22 pm
#16446
Dennis,
I understand your comments are well intentioned and I truly do appreciate anyone taking the time to read and respond to my queries. (If you take the time to look at the previous posts and responses you'll note this)
It does seem however that you are making a few assumptions along the way probably due to not having followed the previous threads, which hopefully i'll clarify here in case there was any confusion.
First of all, I'm a little miffed that in one sentence you're saying that I keep 'insisting' the mixture is spot on and that you wouldn't dispute it, yet you do that very thing shortly afterwards when you say, open quote-I have told you what the answer is obviously you do not agree-close quote.
As above, if you read my previous posts, you'll note, I set the bike back to stock, set initial carb with a Gunson colourtune, (used successfully many times on many bikes), then performed plug chops to tweak the midrange, a picture of the final setting spark plug colour is shown and this tells you the mixture was good erring to slightly rich, as it also did on removal after the seizure), I haven't worried over the top end yet as it has yet to go beyond 3/4 throttle.
I too have several years of mechanical experience and my first 'proper' garage job was cutting my teeth on aircooled VW flat fours when I worked for a VW specialist, (those beetle engines aren't all they're cracked up to be incidentally, i've rebuilt more than a few with holed pistons and burnt valves), I am willing to admit that whilst I have a very good grounding in mechanical works, theres always more to know about specialist one make machines, hence the reason I like forums like this, it allows me to draw upon the experience of those who have owned, ridden and maintained them for years and enables me to make my decisions based upon those experiences hopefully avoiding problems and in the long run helping new owners in the future.
Moving on from that one niggle and looking at other comments i'll hopefully be able to give you enough of a background to the problems.
1-You refer to nearly new pistons, I take it from this that you believe I fitted this, or it was otherwise recently fitted, this is not the case, the piston has been in the bike to my knowledge at least a full year, (much of which it was used little), if not longer, I merely decoked the whole thing and re-assembled after getting it and then primarily because I had the head off to helicoil the spark plug thread.
It displayed minor scuffing to the front of the piston when I removed it for decoke before i'd ridden it and was certainly well covered in carbon indicating it had been in use for some time.
2-You state, when I gave the engine some real work to do!, This I disagree wholeheartedly with, a cool evening, solo rider, (i'm not a big fella), very slight incline and an indicated consistent throttle and speed of 55-60mph I do not consider loading the engine excessively, in fact, in the week prior it traversed much steeper inclines in 3rd and 2nd gear on the way to and from the MOT test, (25 miles each way), during a hot day with me and rucksack, a much heavier load though less consistent throttle and not exceeding an indicated 55 on the clock as I was running it warily being the first proper ride.
Believe me when I say, I wish it were as straightforward as, 'oh yes, it's clearly running lean' that would set my mind at ease and be an easy fix for the rebuild.
As BW says, is 60 on the flat (for even a few miles) too much to ask, i don't think so, it certainly shouldn't be on a 350cc motorbike
(Today I stopped to chat to a young french fella wild camping as I was curious about his bike, i'd passed him earlier and seen what I thought was a heavily laden Yamaha SR500, not such a common sight and a nice looking bike, it turns out, it was a very heavily laden Yamaha SR125, so much so that you couldn't tell what it was under the tank bag, panniers, travel pack and other bits of random luggage bungeed to it, he'd travelled from France, through Switzerland and umpteen other places before hitting the UK and heading to the Scottish highlands, so if him and all that luggage can travel that distance at a good 50-55 average covering long distances at a go on a 125 4 stroke single, then, definitely no, a short burst of 60 unladen on a 350 single is not asking too much).
3-As said, I didn't take BW's statement as a blanket, 'they all do that' statement, and took it in the meaning I believe he intended, that being that in his experience they are more prone to it than the 500.
Thanks to all who've responded so far including yourself Dennis and I certainly don't want to upset anyone or fall out with anyone, I know there are things I can learn about these machines yet and am happy to provide further info on any problem for help diagnosing if anyone wishes, i'm not here to dispute anyones knowledge or experience, ultimately, I want to get my bike running again and enjoy it before the summer is over.
