- Wed Aug 22, 2012 11:38 am
#16484
@Maturin, Dealer agrees Brembo and large disc was not absolutely necessary, but he got them years ago in a sale and they look the dogs cahooners. I just did a 300km ride through some of the lower Swiss alps last weekend. My new warp free front disc coped very well, but I would feel happier if I could get the rear to be more effective. Also used Heidenaur on the front and it was very grippy. After another 10k's it still looked good as new. @Roeland - You are a bit confusing, you bought a new EFI, but refer to having no Lamda sensor and a PAV. Does not sound at all like an EFI. Perhaps you could clarify this. In theory, the lambda sensor tells the ECU what is the o2% in the exhaust and then the ecu takes note of other parameters and adjusts the fuel injection to achieve the correct stochiometric ratio. I understand that with the Dyno Commander, the lambda sensor is redundant, but I do not yet understand what adjustment the user can make. My current preference is to only fit the Hitchcock larger down tube and a tailor made German silencer that achieves great sound and looks better with the the Dyno Commander. The 535 could be done later. Cheers TrevorCH
