- Wed Jul 25, 2012 12:46 pm
#15229
The OEM chains seem pretty rubbish. The one on my 350 classic snapped at about 5k miles. One link totally seized....---
I had to get a top of the range did X-ring chain to get me running again because it was the only one they had in the shop.-----
I cringed at the time because it was £100 and we joked that I should lock up the chain instead of the rest of the bike.-------
I was wrong because it's been on there for 17,000 miles now and I haven't had to adjust it at all, still on the fifth notch on the snail cam.------
Also don't believe all the argumentative old farts (who will now proceed to throw their hands up in horror). A standard 530 pitch metric chain such as are fitted to almost all modern Japanese motorcycles is EXACTLY the same size as a 5/8" x 3/8" imperial chain. I mean EXACTLY because they based the metric standard on the old imperial standard. The ONLY difference is if you get an x-ring chain, then the pins are marginally longer to accommodate the sealing rings. In real terms this may mean you need to bend the chain guard out slightly with your fingers.----
Did I mention I've had a 530 pitch X-ring chain on my 350 classic for 17,000 miles now with no appreciable wear.
