- Mon Sep 03, 2018 5:35 pm
#78858
Marco - its Andrew. I agree that it's a old problem that has not been solved. I think I have eliminated oil , or lack of it as a culprit. Cracked open the banjos and big glugs go oil. On the timing side, although not checked I think it must be ok, reason being that she fires up really easily, no choke. All the dots lined up on the cogs, so should be ok.
And yes it had been the same symptom since new,
So I have changed barrel and piston, oil pump , plungers, oil supply pipe, rockers and richend the fuel with different jets and needles.
I do think it could be excessive heat build up, last time it was around 22 ambient temp. Could not measure the heat of the head, but there was a real heat haze.
The most recent rebuild lasted for less than 30 miles, 5 to the MOT, 5 back then a 10 mile then back, . Clutch in switch off and coast to lay by, swear a lot , calm down then restart and drive home . But now the throttle cable or slide is jammed in the Amal carb, could the heat have warped the carb?
