- Mon Aug 06, 2018 6:46 am
#78346
Hi another thought undo the union nut where the single rocker feed pipe fits onto crankcase and ease out pipe, if you kick engine over oil should seep out of hole. If you get oil there then you have a blockage in the rocker feed pipe. Have you lapped in the oil pump discs in the timing cover, remember return pump has twice the capacity of feed pump but have to remove timing cover to check, lap pump discs, a simple lapping tool can be made with a bit ofround dowel and a couple of small nails when in wood cut the nail heads off leave 5 to 6 mm to engage pump discs.
