- Tue Jul 10, 2018 7:55 am
#77937
It is difficult to know what will happen with both the powerbox and the zener diode in the circuit. For example if one is at the bottom end of it’s tolerance (say 14V) and the other is at the top end (say 15V) then the higher one will never contribute.
A zener diode has to dissipate much more power then a rec/reg. A zener working alone will have to get rid of most of the total output of the alternator - 100-200W.
A rec/reg works by shorting the alternator out before the rectifier so most the power is dissipated in the alternator.
So if your zener still gets hot it’s doing it’s job. If not then it’s on standby until the powerbox fails. (you probably won’t notice depending on how it fails - short circuit or open circuit). If the zener does not have sufficient cooling it will fail very quickly.
The number plate MAY be ok as a heatsink but I doubt that it will be thick enough to conduct the heat away.
Current Bikes
2020 Himalayan
1984 BMW R65LS
2020 Himalayan
1984 BMW R65LS
