Simple example, put a length of 1/4" fuel hose on the end of a medium-small plastic funnel. Fill the funnel full of water with the end of the hose blocked with something, then unblock the end of the hose, suggest you do this over the sink or the garden. See how it gushes out. If what comes out of your fuel tap by comparison (with the petrol tank cap removed in the test I described earlier) is a mere dribble, then your fuel tap needs prostate surgery!
What it boils down to is this - if the petrol can come out of the tank and into the carb AT LEAST as fast as your carb jets feed want to feed it into the engine, preferably a little faster than that to give a margin, you're winning. What you have been describing is the engine using petrol faster than it can leave the tank, the two most likely reasons are a partial fuel blockage in or around the tap, or a blocked tank cap breather hole. Maybe a bit of both?
Now go back to the funnel and 1/4" hose and repeat the experiment with the main jet from your carb fitted the end of the hose. You will see how much gets through the main jet. Your tank/tap/fuel hose will need to be able to supply at least that amount.
#77051
...which is why I suggested earlier using a 1/4" pipe with water flowing through it............To the best of my knowledge there aren't any published flow rate figures for the fuel tap .... eventually experience will tell you, but in the meantime why not set up this very simple demonstrator ??
By the way, prostrate describes someone who is lying on the ground/floor face down, possibly in despair over the unreliability of their motorcycle. The prostate (spelt with only one "r") is the male gland that keeps urologists busy.
By Beezabryan
#77056
also oncologists and radiographers. Don't ask how I know
Ah, I can hazard a guess. I hope they were able to do a decent job. To those of us past the first flush of middle age, don't forget your check-ups, guys.
