#75148
Adrian, I get it now! I thought he was trying to fix a problem with a non-Enfield kick start lever fitted to an Enfield!
By Chris [Stockport]
#75170
Sorry about the confusion; there's nothing Enfield about it... probably.
It's made up of a lots of bits, he says. Though I doubt any train parts, Alan!!! Anyway the principle is the same, so many thanks for all the replies. Here's a picture of it:
#75172
From your pictures it looks like the splines are OK but the Kickstart lever is the wrong one and has been over tightened. If you can't find a lever that fits I would open that lever up again and get some copper or alloy shim in there.
By Leon Novello
#75176
Drilling horizontally would present a stronger bearing face (like a key) to the load than a vertical pin would. Chances are the spline is not hardened, as there are lots of gears and splines in gearboxes in other machinery which are not hardened.
#75181
I'm with Pete F on this, get one that fits, any Autojumble has boxes of levers to pick through and cheap as well. I'm not being negative I just think that any bodge won't last long with a gap that big. And just to add to the fun, I think that actually IS an Enfield gear lever, from a Crusader!
By ric
#75184
Is there still a gap left on the lever after tightening up the nut and bolt?
If not get a file and ensure it is , then get a pack of sewing needles and insert several evenly spaced around the shaft and tighten the nut and bolt fully, then remove/ snap off the bits of exposed needles.
This has worked well for me in the past.
#75195
Adrian asked about the bike, here are some details, just in case anybody has bits to sell:
/i/ Dalesman trial bike made 1971/2 with a Puch 125 engine.[/i]
Thanks again everybody!
