- Tue Mar 06, 2018 12:10 pm
#74609
Which brings us neatly back round in a circle, because we don't actually know the manufacturer and I'm convinced most of these fittings aren't standard, with the possible exception of the disc bolts which look to have been used multiple times by the degree of rounding on the heads.
However, I'm happy enough to consult an engineering chart to see what tension to torque a particular fastener up to. So if I use an M6, 12,9 button head set screw, I need to tighten it to 15 ft/lb. This will stretch it to within 90% of its plastic phase and it wont come undone. 12,9 has the highest tensile strength of routinely available bolts. Locking compound is just belt and braces. If that strips the tread out of the disc, it wasn't a very good disc anyway.
