- Tue Sep 26, 2017 1:54 pm
#71138
Once a nut becomes loose on a clean thread it will soon come right off with any vibration, but pre loaded with a spring washer ( plus plain or not) the increase of friction in threads that is induced may lead to us noticing something loose before it actually falls off! This less than scientific logic may well be appropriate to what we may call "Indian tolerances".... but bear in mind the situation of "soft" joints where settlement of a gasket may be compensated by the give introduced by a spring washer particularly with soft metal castings and low torque values in use, a plain washer may also be included to protect such soft metals.
In reality, I feel that nothing beats positive locking devices such as split pins, tab washers or locking wire, particularly where the slightest of movement may be critical for either safety of mechanical integrity, but right at the other end of the scale I find that painting over with clear (or black for RE frame) varnish is often sufficient (and aesthetically pleasing) for non critical nuts and bolts! This is readily available with brush included from your local nail care outlet, and also serves as an effective stone chip first aid treatment!
