- Sun Oct 16, 2016 11:08 am
#63383
Adding a relay means you have to find somewhere to hide it and run extra wiring to and from it; complicated and not needed. You can pull the supply from the brake light switch circuit in the casquette, through the heaters (fuse and switch) and back to ground in the casquette. The casquette will have a ground point from which a black wire should run back to the bike frame either near the battery or hidden on the seat tube near the rear engine mount where the alternator grounds. Anywhere on the main frame makes a good ground but the steering head bearings are not the best conductors, so although the head lights ground in the casquette, there's a thick black ground wire back to the frame, use that.
