- Fri Oct 07, 2016 2:22 pm
#63104
Scotty - once I got the head to exhaust gasket sorted on the C5, it shut up almost completely.
Pretty sure we have bigger valves on the EFI and I do know the 535 has bigger, cleaner ports. We also have hydraulic lifters, which can be noisier at start up but which should shut up within say 10 pumps once the oil is flowing at pressure i.e. not long at all. Apparently we also have oil pumps on the latest EFI delivering about twice the flow rate of the pre-2011 motors. Any number of things were fixed or improved on the 2011/2012 onwards motors.
Do check your head to exhaust downpipe seal. I used two copper gaskets p/n 582638/A. The "cement biscuit" was as much use as a chocolate teapot. When I went in to replace with the copper gasket, there was nothing of the original cement biscuit to remove, it had disintegrated and been flushed out of the exhaust.
