- Mon Aug 22, 2016 12:38 pm
#61504
I followed the service manual for adjusting the chain tension ... do the RHS first, hence the cam move from notch 12 to 13, then the LHS, also from 12 to 13. After reading the other thread and checking as best I could with a string it did not seem correct and made further adjustments to the LHS hoping to 'true' the wheels up (cams from 13 to 9 on the LHS). It seems I need a better way to measure confidently so will get some longer straight edges and follow your suggestions and report back.
I find it hard to believe that there would be more than about 1 notch difference, hence my request for advice. Thanks all for your suggestions.
