- Mon May 09, 2016 2:27 pm
#58333
Sunshine, to fit a sidecar to a CX500 custom does not require a sub-frame.
A fitting kit has a front lower fitting that bolts to the front of the engine, a front upper fitting that slides through a hole underneath the petrol tank just behind the headstock, rear lower fitting that replaces one of the foot rests, slides across under the bike and is held on by the other foot rest, the rear upper fitting is just a clamp which fit around one of the frame tubes.
I council against trying to even attempt to make the fitting kit yourself.
