- Thu May 05, 2016 5:47 am
#57886
sofiaspin: I've never found a Mk1 Concentric that "performs perfectly".
They all have an insoluble problem of a flat spot just off idle, which can be reduced by setting the idle mixture and throttle slide too rich, but not eliminated. They have fixed emulsion tubes and primary air jets so your tuning options are limited. When tested in the late 70s on a test rig, alongside all the other bike carbs at that time, they came out bottom for mixture control and consistency.
The cold start system is truly appalling. The choke slide has a powerfully progressive effect with throttle position, rendering the bike undriveable when it's in use, and let's be honest: the tickler system is so crude as to be laughable. Yes, it works for a cold start, but at the cost of fuel dribbling down the outside of the carb.
They also suffer from excessive slide wear (compared to Mikunis, et al), but these days that is rarely a problem as bikes mostly do very low mileages.
