- Sun Jan 24, 2016 6:18 pm
#54621
If anyone's still interested. I think there is some confusion between atomic hydrogen and molecular hydrogen. I'm certainly confused
Now, whether a battery gives of H or H2 I don't know.
Quote:
One molecule of hydrogen dissociates into two atoms (H2 → 2H) when an energy equal to or greater than the dissociation energy (i.e., the amount of energy required to break the bond that holds together the atoms in the molecule) is supplied. The dissociation energy of molecular hydrogen is 104,000 calories per mole—written 104 kcal/mole (mole: the molecular weight expressed in grams, which is two grams in the case of hydrogen). Sufficient energy is obtained, for example, when the gas is brought into contact with a white-hot tungsten filament or when an electric discharge is established in the gas. If atomic hydrogen is generated in a system at low pressure, the atoms will have a significant lifetime—e.g., 0.3 second at a pressure of 0.5 millimetre of mercury. Atomic hydrogen is very reactive. It combines with most elements to form hydrides (e.g., sodium hydride, NaH), and it reduces metallic oxides, a reaction that produces the metal in its elemental state. The surfaces of metals that do not combine with hydrogen to form stable hydrides (e.g., platinum) catalyze the recombination of hydrogen atoms to form hydrogen molecules and are thereby heated to incandescence by the energy that this reaction releases.
Molecular hydrogen can react with many elements and compounds, but at room temperature the reaction rates are usually so low as to be negligible.
Classic C5 Euro 4 at the moment.
Also CBf250.
Also CBf250.
