- Tue Oct 06, 2015 7:31 pm
#51486
Scotty writes: "Always thought 20/50 grade oil was thin when cold and got thicker as it heated up if so you would expect tappets to be noisy when cold and quiet when hot."
No, it doesn't work like that. I can't remember the two temperatures used for testing, but say they are 0C and 100C. A 20W-50 multigrade has the same viscosity a 20-grade oil would have at 0C, and the same viscosity a 50-grade oil would have at 100C.
HOWEVER, a 50-grade at 100C is MUCH thinner than a 20-grade at 0C, so in reality a 20W-50 multigrade still thins out as it gets hotter; it just doesn't thin out as much as a straight 20-grade would.
