- Thu Jul 09, 2015 9:17 am
#49294
Hi Wilf,
That's right, although I did it by taking the glass off and taking the mechanism out of the case entirely - much easier to work on.
I wasn't able to jam the mechanism with the needle at 30, but it didn't matter because I found I could jam it at about 45 with a piece of metal rod pushed through the mechanism. At 45mph the error was still about +5mph, so that was OK. I took a mental note of the exact speed the needle was showing.
The needle was on extremely tight, so I bent a couple of old screwdrivers so they looked like tiny crowbars and levered the hand off the spindle. It is essential to lever AGAINST THE TWO SCREWS near the middle of the dial, not onto the dial itself or you will ruin it.
I then replaced the hand exactly 3mph further back and gently tapped it down. Remember, I chose to leave the speedo 2mph fast at 30mph, so it would be spot on at 70mph.
There is one last job. Originally the needle pointed at 0 when the bike was at rest. It now points at -3mph, obviously. If you look in the mechanism there is a long metal strip which acts as a back stop for the shaft connected to the needle. Just bend this with a pair of pliers until the needle is pointing at 0 again.
Clearly I've no idea how accurate the speedo is below 30mph, but I don't care about that. I rechecked it with GPS and can confirm that it is now just what I expected: 2mph fast at 30, spot-on at 70, and a declining error between 30 and 70. Most satisfactory.
