By Chris Tindal
#46411
Mines now done over 10,000 miles and works well, about 5 mph over true speed. At around 4K it started waving erratically so I stripped it and gave all the workings a tiny smear of HMP grease and it's been great ever since.
By Nettshubby
#46412
As regards the indicator warning lights, I read once that if you can see the indicators, a warning light is not necessary. I wouldn't think a neutral light is required for MOT, so that just leaves the high beam warning, which I would think is required. The general rule for all the lights is if the lights are fitted, they have to work, and if you remove them and go for a daylight MOT, the switches have to be removed too!
By vince
#46415
Hi, Strangely speedos are not part of the MOT test. There is no procedure to see if they work.
By Exile
#46443
I recently fitted Thumper up with a GPS (Tomtom Rider). My speedometer is crap. According to the GPS....
Considering that we are in the 21st century, one would have thought that a better speedometer wouldn't be too hard to design, build and manufacture.
By Thack
#46444
Exile writes: " My speedometer is crap. According to the GPS...."
I tested mine over several runs against a GPS, and plotted the results. On mine the speedo was 5mph fast at a true 30mph, and 3mph fast at a true 70mph. There was roughly a straight line graph between those two points for 40, 50 and 60mph.
I was expecting a fairly complicated recalibration job, but I realised I could get pretty damn close with little or no trouble. I took my speedo to bits and moved the needle back by 3mph. Now it is 2mph fast at 30, and cock-on at 70 (with a declining error between). I was pleased at such a good outcome for a trivial amount of effort.
By Thack
#46445
Oops - I forgot to mention that I had to move the needle stop so the needle pointed at 0mph when stationary. Very easy - just a metal strip that you bend with a pair of small pliers.
Is there any special technique or preferred tool for removing and refitting the speedometer bezel? A.
By Pathfinder856
#46459
Hi guys
Thanks for the Info,
My bike does not have a Neutral light. Anyway, but I'm sure the High beam and indicator repeater light are required, even though with new bulbs I can't see them in the daylight
But I did not want to modify anything that can't easily be put back to standard .
I have ordered another Smiths replica Speedo and hope that one is better!
I am not too worried about a little over reading , but was hoping for a steady needle rather than one that waves around like the factory fitted one does.
I may well take the old smiths one that doesn't work properly apart and have a play with it .
Having used the sat nav in my car , I find that there is a similar speedo error on that and that is certainly a lot more high tech than the bullet.
However the Smiths Replica. Speedo and the Lucas Ammeter certainly do look the part on the bikes as opposed to the standard items.
#46460
Adrian a mate of mine has a pair of bezel pliers, I think they belonged to his father, they do a great job
By Pathfinder856
#46469
Well, I ordered another speedo yesterday, thanks to Hitchcocks Excellent service. It was delivered today and I have just installed it.
And it is not doing what the other one was, so I guess it was a faulty one!
Regards
Rich
