- Sat Feb 07, 2015 12:19 am
#43917
Internationally, leaded petrol contained up to .45g of tetra-alkyl lead per litre, though typically the levels was between .2 and .3g per litre. As well as increasing the petrol’s Octane rating, and acting as a valve seat protector, it also acted as a catalysis that burnt off carbon residues from spark plugs and helped to keep them clean. Along with the ‘lead’ were organic chlorides and bromides which further prevented excess fouling of Plugs and lead oxide deposits on piston crowns. None of these ‘scavengers’ are present in unleaded petrol.
The typical density of unleaded ‘Super’ petrol world wide is 0.750 Kg per Litre, compared to 0.735 Kg per L for leaded petrol. The higher density of unleaded petrol provides greater energy content per litre, but requires a slightly LEANER air-fuel ratio to maintain the correct chemical balance during the combustion process. In the real world this equates to a 1-2% change.
Mean time, dont just keep fitting 'the same plug' go hotter, projected tip, and or close down the gap a few thou.
