- Tue Dec 16, 2014 4:49 pm
#42523
I normally keep well out of threads like this so this may well be my first and last post on the subject.
It would appear that Tim NZ is pretty much correct, Tribonnie states that the Hitchcocks scramber with twin plugs runs at 8 deg retarded compared with a single plug, this fits in with my experience, so if one plug stops sparking for whatever reason then the engine is running 8 deg retarded, which will cause it to overheat.
The makers of double ended coils have no real reason not to let them generate double the voltage and in my experience they do just that, I have in the past built many twin plug engines and never had a problem with a double ended coil set up, indeed the link posted by Thack states that a single coil generates eg 12Kv and a double ended coil generates 12Kv + 12Kv = 24Kv.
I seriously doubt that the problem lies with the coil, a twin plug set up is more efficient at burning all the fuel in the cylinder and at a faster burn rate, therefore it is more likely that the ignition is still too far advanced and or running lean.
In conclusion I rather feel that perhaps some of what has been posted before has been misunderstood, before jumping back in guys read through it again and try to understand the other posters point of view, the written word won't always come across in the same way as a face to face discussion.
