- Fri Jun 27, 2014 9:59 am
#36824
It is possible to lap the faces in and run without a head gasket, but the gain to the compression is tiny, if going up from the std 6.5:1 or so, you probably won't gain very much. On a 350, 1mm of gasket space removed will give just short of 4cc chamber space reduction over the piston. For a 500, it will give a reduction of 5.5cc.
As an example, if you already have a 500 set at 8.14 :1 [70cc combustion chamber space] and you remove 1mm by doing away with the head gasket, you will end up with 8.75:1. The higher the C.R. to start with, the greater the gain will be as the reduction of either 4cc or 5.5cc becomes a bigger proportion of the combustion chamber volume you are starting with. A 350 at 6.8:1 will only reach 7.25:1 with 1mm removed by doing away with the head gasket. On the machines I tune, I usually shorten the cylinder barrels as well and for the record, there are several 350 and 500 Bullets out there, running at up to 10:1 C.R. with no problems [or fuel additives] and one Crusader road / sprint bike residing over at the I.O.M. with an initial accidental 13:1 C.R., which I thought might have to run on methanol, but ordinary unleaded worked fine, so I left it on petrol. that one is VERY fast !!
My squish band modification has been used successfully on the racing Enfields and one of the 'Asbo' Bullets may be getting one soon as well. Regards, Paul.
