By Jonesy
#32056
HI AMERICAN COUSIN,IVE OWNED MY 08 BULLET FROM NEW AND I USE 80/90 GEARBOX OIL,IT HAS THE INDIAN MADE BEARINGS.IT HAS COVERD OVER 23000 MILES AND IT IS 100% OIL TIGHT.YOU WILL ALSO FIND THAT YOU HAVE A MUCH SMOOTHER GEAR CHANGE
#32328
Jonesy, 08 with a 4 speed must have been the last of them, so do you know when the factory started putting oil in them instead of grease.I assume it is a left shift 4 speed?
By simon
#32333
I've got straight 50 in my 92 four speed box and it shows no signs of leakage, which reminds me it might be time to check it!
By Phil Ashbrook
#32483
I have a classic 4 speed with new bearings ( inc bronze lay shaft bearings and scrolled floating inner steel bush ), oil seals and felts and the pathetic gear change shaft O ring, all filled up with pure 00 grease mixed with engine oil at 20% no leaks after some epoxy glue ( blob ) over the selector pin bush screw at the back of the gearbox ..it weeps not .
By simon
#32499
Well pride as they say comets before a fall and so I have to admit that my bragging about no oil leak was because my gearbox was pretty much empty! Topped it up this arvo along with a change of carb slide to a number 3 to see if that will defeat my flat spot.
