By Beezabryan
#31081
An alternative Jenks if you want to periodically run the motors is to fill the tanks to the brim & run the motors till the float bowls empty
#31085
Jenks, running engine periodically is bad practice unless you get the engine and oil up to normal working temperature. Tricky to do with the bike stationary without getting involved with fans etc.
By Midge
#31089
Also running the engine occasionally won't make the fuel any newer. It will use up a tiny bit, but you will still have your original problem and also the new problem of moisture in the oil and engine.
By jenks
#31091
Thanks for your input guys,seems like I need to use one bike and drain the others.
Happy Xmas to everyone
Shortest day next week,so will be riding again soon.
Cheers
Jenks
