- Fri Nov 15, 2013 10:48 pm
#30390
Hi Shane, problem there is nothing straight forward to replace on them I change parts that look identical to what I have taken out and some work and some don't. Pull the detent plunger out and see what the end of it is like it may be worn and not properly locking it into gear,Try screwing it in and listen for the click as it rotates, screw it in till it stops and then screw it out a couple of clicks. It may also be the adjuster plate needs a tweek, there is a lot of little things that can cause these problems along with slight clutch drag. I spent several days this week working on a gearbox that would drop into gear when pushing the bike and leaning it over to the left, upright it was fine. Must have had it apart a dozen times and replaced many things including pulling the motor out to replace the selector fork and finally got it sorted, but the problem is at the end of the day I didn't find what was causing the problem but it now works fine.
