- Wed Mar 28, 2012 6:30 pm
#10992
Osmerus,
2 problems here solonoid sounds like it has failed and the neutral switches can be dodgy as well. Get apiece of wire with an aligator type clamp and clip it ont the neutral light switch on the lower rear of the gearbox and with the ignition turned on conect the other end of the piece of wire to the frame somewhere and the neutral light should come on. Then see if the solonoid will click be pressing the starter button.This will only test the circuit, not fix the solonoid but at least it eliminates one of the problems. Doesn't fix it either but tells you where the problem is
Osmerus,
