Cranky wrote: ↑Sun Dec 13, 2020 1:38 pm
Hope im not interrupting or changing the subject but is the Avon the original Chennai tyre. I ask because I have an Avon and I am in Thailand, The tyre is so hard I can run 5 psi and the bike is a 2017.
The finger nail test says it a very hard compound.
They generally came with an Avon Speedmaster MK2 on the front and a safety Mileage on the rear.
I wonder how old the tyre itself is? They generally have a date code on the side.
Something I've found is that the tread pattern has little to do with the grip unless you are on loose or snowy surfaces. A high silicon compound is best for winter performance on uk roads. Not good if it's icy, but then nothing much is short of studs. The Michellin Road 5 tyres I put on my VFR750 have remarkable levels of grip on cold, wet roads despite having a very "sports" orientated tread pattern. The tread on a road tyre just clears deep water to prevent hydroplaning and a bullet can't go fast enough to hydroplane so you could use slicks on one if you really wanted.
Contrary to what many think, an agressive, offroad-style tread pattern isn't actually all that good in winter. It's all about contact patch size at the end of the day. That tyre compound needs to be on the road to be of any use. An exception to this would be snow where big gaps could come in handy.
Oddly, I think the safety mileage does win in this respect somewhat due to having a comparatively large, square contact patch which tends not to come up off the road when cornering.
