By Chris Tindal
#16694
Hi PeteF, yes I know but in this thread it was about swapping engines not top ends.
By Wiseowl
#16695
Chris, 350 and 500 castings are the same as far as fitting the engine in the frame goes, but not quite the same in other respects. You can't stick a 500 barrel on a 350 bottom end.
And ain't that a shame!
By Chris Tindal
#16699
Actually you can, but it means moving the studs out and boring the crankcase mouth, easier to get a 500 or tune up the 350.
By simon
#16708
I'm not sure whether they give a lot more in the low end although Mr H can give you a graph of the different performance stats. What I do know is that the bike revs a lot more freely and can cope with the additional air and mixture available from the bigger carb.
#16709
Martin,
I was unaware of the fact that you had cars crawling all over your back was fun but each to their own I thought you had a problem
#16710
Well anything's possible, but I meant you can't just slot it on. Tollgate Classics will convert a 350 to 450 but at a cost. They also do a tune up package which includes HC piston, head porting and a bigger carb, again, at a cost. I've done quite a bit to my 350 and the CR conversion was definately the best mod.
#16714
Hi guys-----------careful with that engine for sale, it's an Electric Start according to the photo. BTW, I've bought some items from this chap and he seems OK.
#16715
---------I've heard that for a PRICE you can get some PARTS from a guy in Gloucestershire including a 350 crankcase set machined and modified to take the 500 crank and barrel. But I never told you that on this forum, OK ?????
