- Tue Jan 11, 2022 5:24 pm
#99669
Pre unit 2004 Indian bullet with hitchcocks 612 conversion kit.
The engine ran fine for about 2500 miles. I upped the compression by removing one of the compression plates. Shortly after, it suffered a seizure (which freed off and ran for another 600 miles). The jury is still out as to if this was the cause or effect of a split/crack in the piston through the gudgeon pin hole but I'm erring on the side of effect. it's been rebuilt again at a lower compression.
I've been having an ongoing problem with noise under load which I took to be pinking. I have also had several bent pushrods. It's a clattering/mechanuical noise and only happens when the engine is warmed up and under load at moderate revs. I have fiddled with the timing and carburettion ad nauseum to no effect.
I've been trying Bullet Whisperers trick of advancing the inlet timing and I thought I'd try it back to standard to see if it made a difference. Now, this is the first time I've been in there with the engine still fairly hot, which may or may not be relevant.
When I rotated the inlet cam and slid it back in, I noticed I didn't have to lift the follower to slide it home. On further inspection, the folower is hitting the crankcase "stop" before it touches the cam. There is a gap I can get a feeler gauge in. At the "fully closed" position, there is a 0.004" gap between the cam and the follower with the follower resting on the crankcase casting!
There is no perceptable play between the cam and the spindle. The cam itself doesn't look particularly worn or damaged. But even if the cam was wearing, it can't possibly continue to wear beyond the point where the follower is in contact with it? The followers are free to move and do not appear "wobbly" when rotated.
That's not the only issueI When I removed the exhaust cam to get a better look, the spindle came out with it! It's finger tight. The inlet one is stubbornly not.
So. I'm pretty sure I've identified the source of the noise. Also probably the reason for bent inlet pushrods because they aren't in touch with the cam all the time.
Raises some questions. The first is what's going on with the inlet cam? Could the spindle be bent? It looks slightly rotated on its seat now (pic below, the flat is misaligned) and it definately wasn't when it was assembled because I checked my build pictures. So is the spindle itself slightly eccentric? Or is it walking out of its seat and angled marginally down? Or has the casing deformed? I was thinking about simply replacing the spindle in the first instance but there are no standard ones in stock. Or am I going to have to burr down the crankcase "shelf" where the follower comes to rest?
Second, what about the exhaust spindle? It'll need replacing. Does anyone know the diameter of the standard spindles where they fit into the casing? My current one is finger tight but without any appreciable play. I miced it up as 15.87mm (0.6248"). If they are the same as electras, those are 15.90-15.93 standard fitting which would make my spindle under diameter.
Are eccentric/adjustable cam spindles worth bothering with or just something else to go wrong? There is moderate backlash on the cams with the standard ones. That may be a moot point because I'm guessing I'll need an oversize spindle (or to fit it with green fitting compound).
Also any tips for removing the spindle. Our hosts are out of stock of pulling tools, can something else do the job? May need to fabricate something?
