- Fri Oct 23, 2020 4:47 pm
#93655
Hi Im trying to fit this top yoke (Indian) to my 1979 Bullet frame, but the steering stem ( 1979) does not protrude through the top yoke far enough to thread the top nut on. If I fit the pinch bolt as is it will tighten against the stem thread, which is not good. a bottom yoke with a longer steering stem would solve the problem. do they exist ???? I can partially solve the problem by using Mr H's long top nut and machining a deeper counterbore in the yoke, but this doesnt solve the pinch bolt / thread issue. thanks in advance
