By Hardhat_Barry
#8173
Is this the right headlight for a model G I seem to have a large mouth type hole at the bottom (picture is rotated 90 degrees)?
#74857
Barry, when posting questions about originality it helps a lot if you say what year the bike is. The Model G ran for a long time, 1946 to 1957 in various different guises and the specification changed a lot over those years, not considering all the bits fitted by Previous Owners (the Americans just call them POs!) That underslung pilot light type of headlight was fitted to a lot of early 50s bikes.
It looks the right shape.
Scalyback, if you're reading this, does Barry's ebay item match what's in your old Lucas catalogues?
#74865
That Ebay one is different, it has a rubber grommet to mount it on a flat surface. You need the type that is a lens to go inside the cast alloy cowl that is fixed to the bottom of the headlight. It also has a fixing clip that sits behind it. There should also be a rubber seal to go round the edge but you could use black silicone sealant for that. I might have one somewhere...
By Hardhat_Barry
#74868
Hi Mark,
If you do find you have one and are willing to part with it let me know.
Is it worth me putting a wanted ad in anyway in the buy/sell bit of the forum (I feel I'm going to put a lot of wanted for this Model G)?
#74873
Barry, I've had a quick look and can't find it but I will keep looking.
