- Mon Sep 17, 2018 7:58 am
#8817
Hi I have noticed the brakes on my 91 Bullet 500 are not quite right although they do work. When I bought the bike the rear brake was set up so it was far too sharp and would lock the wheel at the slightest touch and the front brake was far too weak. I adjusted the rear brake and put a new rod on as the old one was bent up and set it so I have alot of brake pedal travel which I like. The problem is when braking especially when the bike is cold and I start the run the rear brake doesn't do much and then gets to a point where it makes a loud metallic growl and then locks the wheel. It does it a couple of times normally and then it is ok and the braking is progessive however I have noticed it has started doing it a bit more recently when I am riding normally.
The other thing is my front brake this one works ok and doesnt have the growling issue and doesnt lock the wheel however it works well stopping the bike from going forward but is useless stopping it from going backwards. If I am on a hill it doesnt work and the bike rolls back unless I am really heavy handed with the brake lever. This isnt so great as I mainly like to ride the country lanes in the South Downs so I deal with hills alot.
Admittedly since owning the bike (about a year now and doing about 2000 miles) I have not had the brake drums apart to inspect them so am thinking that maybe they need some attention, perhaps new shoes and a new heavy duty cable for the front and replace some of the front braking arms etc with new shiny bits from our hosts.
Any advice would be great.
