- Mon Jun 11, 2018 11:52 am
#77463
Another thread on here identified the same surging at low throttle, and traced it back to starting the bike up when on the side stand. I may have done likewise, as the bike was running fine, then the stuttering started. It would appear to upset the ECU and the answer might be to repeat, then stop the bike, then start normally. Certainly the mods were done long before the stuttering raised its head. Too many sensors and wires going in and out of the bike. All I am after is for smoother running across the rev range and a bit more acceleration and top end. It only has 1300 on the clock so it will loosen up by 3000.
