By calv
#8502
Has anyone ever had there timing gear slip on magneto. I'm guessing mine has do to misfiring the other day after running perfect for a hundred miles or so.. but can't understand why the nut was tight and gear was slightly tough to pull off. The mag has been tested and is good.
By Bullet Whisperer
#76965
If the nut was tight and the gear was difficult to pull off, I would think your misfire was probably caused elsewhere.
By calv
#76966
Why would it kick back on me when trying to start engine
By calv
#76968
I had a look at the timing and seemed ok .points open up at 3/ 8 btdc.but Was
Still kicking back in fully retard and full advanced.
By calv
#76970
Just wracking my brain. Could a blockage in the carb cause engine to kick back ??
By calv
#76972
Thanks for the help. Will av the monobloc stripped apart l8r. Hopefully no more problems .
