By nicky
#7491
Hi does anybody know what colour wires are left and right on the indicator stems on a 1995 Enfield Bullet.
i am rebuilding this bike and the indicators have been removed.
The coulours i have are light blue and dark blue on one side and dark blue and red on the other i persume the dark blue is the negative. thanks.
By zonggong
#68795
The wiring diagrams (3 from different sources) I have for both the 350 and 500 Enfield Bullet show the left trafficator as black/white and black: the right trafficator as black/green and black. The black is the earth. This is correct for my 1990 350 Bullet. I don't think this helps you much. Perhaps the colours were changed later.
By nicky
#68796
sounds same as the diagrams ive seen inclusive of the 95 bullet. thanks
#69066
Hi NICKY----- might I suggest that you use a separate earth wire wherever possible and take it straight back to the battery ??.......I've done just that thing recently when a bad earth ( or ground ) on my rear lamps caused the left indicator to appear to come on when applying the brakes..........A rather irate "Gentleman" in the following car verbally challenged my parental ancestry whilst at the same time indicated with his right hand that I had only 2 miles to reach my destination !! ( At least I think that's what he meant !! )....You meet the nicest people on an Enfield ( With apalogies to an old Honda advert )...
