- Tue Jan 30, 2018 9:01 pm
#8044
Just dropped the bomb on a 612 kit from our hosts. Scary, now spent more than the cost of a brand new UCE bullet on this project! But anyway. I've just split the donor engine. A 2004 500 bullet. A few questions and observations for interest.
First off, I was wondering if there's anything I should be doing while I'm in here? It's getting new bearings throughout and the crankcase will need to be relieved to fit the new exhaust cam in but anything else?
Secondly, It looks like two of the pairs of stud holes have been machined to take dowels. None are shown on the schematics and this is definately the first time this engine has been split so it's like that from the factory. I'd intended to ask my local machinist to fit dowels when he's fitting the bearings etc. but it looks like I should be able the throw some in there anyway. Is there a reason there aren't any?
Third thing. I'm intending to re-instate the "original" breather system. This engine still has the castings from the original crankcase breather on the upper left side just below the barrel present but not drilled. I've ordered a Redditch style bolt-on breather stub and I'll run it past my machining guy to see if there's enough alloy to face-off the crankcase casting and bolt that on. Failing that, it'll be a case of drilling the cast stub and tidying it up enough to fit a hose to it (maybe cut a thread on it and fit a hose-tail). Also lets me look at the breather hole between the crankcase and oil tank. It's tiny! No bigger than 5mm. I'm going to solder this closed.
On the last one I had apart, the return hole between the crankcase and the timing chest also seemed awfully small for the volume of oil the pumps can chuck out to passively return through. I was considering enlarging the hole (maybe slotting it to maintain the oil level in the timing chest) Someone at the factory must have thought so too, this one has the small hole then another, bigger one above it.
Hope I got my HTML tags right!
