By scotty
#7765
Has anyone any clues on setting gear selector plate. I can get 1st neutral then straight to 3rd and top.does the selector plate adjust the two btm gears one way and two higher gears the other way or could i have the spring loaded chisel point indent screwed in a bit too far, old one was pretty knackerd when i removed it and yes notched gear selector plate is in right way round.
By vince
#71326
Hi, a quick check can you select 2nd gear with the neutral finder? If the answer is yes and it stays in gear, the problem is in the selector mechanism. Vince
