- Wed Jun 28, 2017 12:06 pm
#7449
My 1999 500 Bullet has a Boyer MkIII system fitted and I've added the powerbox to replace the reg/rec. It runs well but is reluctant to start. I know that the starting issue could be something completely different, but the Boyer website states that you should use a suppressor plug cap otherwise the electronic ignition could be affected, causing poor starting. I've got an un-suppressed plug cap - should I change it? Thanks for any wise thoughts.
