- Tue Jun 20, 2017 12:28 pm
#68449
Ric! - ' One problem associated with bad gear changing on the 4sp box is because more often than not the setting for the adjustment plate is bang on mid position when it should err towards the downchange. The reason being because its easier to push down on the leaver than pull it up. "
i feel like this is the place im not getting right, i have replaced the figure 8 spring behind the plate as it looked pretty done in and i think it the placement of the foot control ratchet that is causing these headaches. our hosts own guide to my original problem of the kickstart pawl says dont touch the adjuster plate or the gear operator selector assembly... but i had too, to replace a really worn out selector assembly ( the spring was continually sticking which is why in the first place i was having trouble with this all)
so, waiting on these bits to arrive and then i guess its just a matter of rail and error in getting the adjustment plate and gear assembly selector in thier right places / settings.
This is such a classic headache, everything was working so smooth and happily before i took it apart :p hamfisted.
thanks loads for all your replys.
Binery ! - i do defiantly dream of being able to give my bike that one extra gear, the 5 speed of a newer bullet i had a few years ago in india was great, but overall i prefere and went for this older chappy ( 1992 ) by choice. tho i do miss the gearbox :p im not in position at the moment to spend anything at all at the moment otherwise ive got a few things id like to do to this bike. i drem mostly of this idea of doubling it up like a musket 1000cc or the carberry bikes that chap in india is making.
right now id settle for my old plodder back in action.
raises fists to the sunny sky... whyyyyyyyyyy nowwwwww.
waits for postman.
waits for postman.
