- Sun Aug 07, 2016 3:22 pm
#6561
Hi all,
Got a problem with my wife's low mileage, completely stock, 500 Electra X.
When it gets hot, it cuts out, but only when I pull the clutch in. It's a re-creatable problem - I can run it up the street at 30mph in 1st, get to the end of the street, pull the clutch in and the bike will die. Wait say 30secs and it'll start.
We've removed the ignition switch, tried bypassing the ammeter, unplugged the reg/rec, remade the multiblock connectors under the seat with new ones from VWP. Swapped the coil for a new one, new spark plug, new battery, disconnected the side stand cut out...
Pulling the clutch cover off revealed the stator looking a bit nasty - the plastic around the ends of the coils has broken off in several places, and there is fine "metal paste" stuck to the magnets.
something// is getting hot, but I have no idea -what-
The carb has been fully cleaned several times, it's spotless in there.
Like the NHS, I don't do well on non-obvious problems. If it's clearly broken, I can fix it. When it's odd I get confused...
Heylp...?
Heylp...?
