- Thu Jul 28, 2016 10:18 am
#60536
ginetta lad
these are the diagrams from our host, as can be viewed by any one.
there is no need to waist the splined part of the schaft, thats the part you need.
the green line is what you remove and reattach the remaining splined axel to the part where the arrow point.
which length you keep is to your preference, depending if you won’t the lever to stick out a little more or not!
standard the gear lever sits level and sticks out just enough to not touch the seal , so you have to rig it up before you weld it together.
personal i prefer it to sit a little higher and stick out a bit more and use a bushing on both sides but thats a personal choice.
ginetta lad
