- Tue May 03, 2016 4:55 pm
#6212
Hi All. I have been having problems over the last few years of sizing pistons. As I see it its either heat or lack of oil that is the problem. So i am going to change the bits in the carb so I run richer, and then get all the timing done and have the carb set up properly. Hopefully that should sort the getting to hot problem out. The next is the oil supply. It was using alot of oil, but no smoke or oil wheel so must have been spat out of the exhaust. I will get teh barrel honed and a new piston and rings, hopefully that should sort that. Next is the oil possible problem. What do I need? High capacity oil pump? What about the oil pump worm and spindle? Would I need it? And what about the Pressure relief valve kit? Again is it necessary.
So my shopping list
Barrel and piston
Head gasket
Worm and spindle
Pressure relief kit
With getting the timing/mixture set up right, and the above have i covered all bases?
its a 2004 500cc 65 Bullet with 6000 miles on the clock. Amal carb and stubby exhaust.
All advice gratefully accepted
So my shopping list
Barrel and piston
Head gasket
Worm and spindle
Pressure relief kit
