- Sun Aug 30, 2015 6:42 am
#50666
Have started the strip down, the plug was a bit black and sooty, would that not suggest a rich mixture? Or is it oil getting past the rings? The bore looks ok, but will do a closer inspection in the daylight. The bore was matched to the piston by a reputable company so as far as I can see it the only possible problems are
1 Oil starvation, - on stripping looks like there is pleanty getting around
2 Weak mixture, - I had it set on the middle notch, so move it down to the bottom notch, lifting the needle up. Amal carb by the way
3 Timing - I had it serviced not that long ago, distance wise. Would have gone off since then?
So other than inspect for scoring on barrel and piston and fix. Richen the mixture, and check timing that's it?
Any simple ways to check the timing?
Thanks
A
Thanks
A
