- Sun Apr 26, 2015 11:00 am
#4973
Hi all,
Wonder if anyone can help?...
I've recently had some wires cut (by some mindless wan***s) on my royal enfield electra efi and am just wondering if the bike should start without the neutral indicator switch connected?
The neutral switch wire was one of the wires cut and but I don't know if this would stop the bike from starting? The engine light comes on and goes off as normal so therefore doesn't display an error code.
The other wires cut were 3 yellow wires coming from the gear housing (?) On the lower right of the bike, all housed in 1 black tubing going to underneath the front of the seat. Also, a green and white wire next to them.
I have managed to solder all the wires back together but my problem is that it was guess work as to which yellow wire to connect to another yellow wire... If that makes sense?! I tried to match them up by the length of them either side of the cut but it was all guess work.
Does it matter if I get it wrong with these yellow wires?
