- Wed Jan 14, 2015 6:29 pm
#4586
Hi again,
In another thread someone made a comment that I should replace the ball bearing on the clutch rod for a ceramic one as this transfers heat less then a metal one.
I was looking in the partslist (and on my bike) and the '55 does not have a ball bearing between it's clutch rod and its clutch rod pad.
My question is should I replace the clutch rod or clutch rod pad with an indian so I can install a bearing, cut down the clutch rod or clutch rod pad to install a bearing or just leave it as is?
