- Wed Oct 29, 2014 9:41 pm
#41197
Wheel off, caliper off, pinch bolts (which also hold indicators on) undone, front mudguard off, slotted screws off forks, loosen fork gaiters, unbolt the fork drain screws from the bottom of each fork, unscrew (well, actually screw) fork legs from casquette (you might need a large allen key, 10mm I think, to do this from the top or you might be able to turn the main tubes by hand undeneath the gaitors).
Getting there now! Next, putfork leg on bench in a vice which grips the main tube, remove the circlip at the join between main tube and fork end, then hit the threaded area atthe base of the leg where the fork oil drains from with a rubber mallet until the fork top and bottom separates. Use a c-spanner to undo the plunger from the main tube, remove spring then rebuild. Change oil seals (2 each side - be careful not to split the fork end, use heat and special fork oil seal removing sleeve!!!!!!!). Use new orings at fork top and for the slotted screw at the very top. Rebuild front end.
1 hour to get forks off, 30 mins to separate tops and bottoms and get springs out, 1 hour to rebuild forks and 30 mins to rebuild front end... if you have done it before and if fork separates and if seals come out nicely:) If not done before, or any other issues, give it a day. Sorry it isnt what you wanted to hear! Whatis wrong with your current springs?
