- Mon Jul 21, 2014 10:15 pm
#3932
Hi all... advice is most needed for removal of both inlet and exhuast valves. I run the tuned head from our host. The spring retainer set up is different from the stock head. I have the valve remover tool and it works super on the stock valve set up, but on the tuned head the split collars can't be removed when the spring is pressed together. There is simply not enough room in the center hole on the tool. What to do? Maybe drill out the hole to a bigger size? Anybody here having experience on removing valves on the tuned head?... regards Jacob
