By Chevalier Noir
#2634
Hello.
At the moment I have a poor single cam front brake :
http://u20.direct.atpic.com/54911/0/2728430/600.jpg
I want to update with a double came brake, reusing my drum.
I do not understand the difference between
- the TWIN LEADING SHOE CONVERSION ref 144705 at 95 UKP
- and the TWIN LEADING SHOE CONVERSION ref 92685 at 99 UKP
and then why the "improved version" is cheaper.
Any idea?
Thanks
Le Chevalier Noir in france
#28110
Looks like the difference is you get a cable with dearer item (which you might need)
Be aware that you have a fiddly job ahead of you to get this TLS working properly. There is a tech note on here to help you.
By Chris Tindal
#28113
Did the modification to the TLS last week and its completely changed the bike, I now have a brake that works for the first time in years, well worth doing.
#28116
Hi guys-------------- you might want to consider upgrading the linings when they are due..These modern compounds are a big improvement on the original items...
#28132
Interestingly Alan, I "upgraded" the linings and found no improvement at all (and yes, they are set up correctly and "run in")
I suspect that the later bikes (mine is 2008) already had decent linings.
By Chevalier Noir
#28531
Hello
Master Hitchcocks confirmed me today that the brake with cable uses the same parts as the "improve brake".
So yes, the difference is "only" the cable.
