- Tue Sep 04, 2018 3:53 pm
#78894
When cold, my oil level doesn't register on the dipstick at all. After a brief run and shutdown -allowing the engine to cool for 5 minutes or so- the oil appears to be about halfway (perhaps even 3/4) to the top fill mark. Is this normal? I'd expect to see a slight difference in the cold/hot readings, but surely not that extreme, right? I'm diligent about setting the piston at TDC each and every time I park the bike. I've got quite a bit of oil leaking past the timing gasket (need to fix that!) on my rides and collecting on top of the crankcase, so I'm fairly confident the level's sufficiently full when warm.
